Transmission Trouble?
Old Mar 11, 2006 | 01:23 PM
msjamz's Avatar
Default Transmission Trouble?
I have a '95 camaro with 131k miles. Lately it seems like the transmission is slipping (very slightly). Checked the fluid and it looks dark. Any suggestions?
Old Mar 11, 2006 | 01:27 PM
bjames5's Avatar
Default RE: Transmission Trouble?
I would see about doing a complete flush of the system by the dealer or other reputable transmission shop. Sounds like its way past due and could have overheated at one point. If this does not cure the problem it could be time for a new one. Good luck.
Old Mar 11, 2006 | 09:04 PM
mattvogt's Avatar
just put it on a lift or in your driveway, take off the pan, switch the filter, put on a new gasket, and bolt it back on. Add new tranny fluid, start her up. it should be good. Only a 2 hour job. probubly not even.
Old Mar 17, 2006 | 07:11 PM
Being that the fluid looks ugly as you said, you may want to get a power flush from a tranny shop and get rid of all the fluid, dropping the tranny pan only gets rid of the fluid in the transmission case, but still leaves several quarts of old stuff in the torque converter. Make sure the proper fluid is used (Dextron III), as the wrong fluid will case wierd shifts, and make sure the transmission filter replaced.
Old Apr 1, 2006 | 08:10 PM
mike86rs's Avatar
If the fluid is dark it usually means it is burnt, from the clutches slipping a getting to hot. With that many miles I have it rebuilt.
DDRDiesel
Aug 3, 2014 02:29 PM
Nytric
12
May 5, 2012 10:24 PM
Vanderkooy325
Jul 8, 2009 08:01 PM
shrews61
Mar 22, 2009 05:23 AM
scottsnody83
Feb 20, 2009 03:38 PM
