squeeking clutch
Hello, I have a question in regards to my 1996 V6 that has 33k miles.
Recently, I started noticing that whenever I step on the clutch pedal I get a squeeking noise. It does not do it when the car is cold, maybe after 15 mins of commute is when it does it. There are times that it's tough to put it on 1st gear from a dead stop (it does not make a grinding noise). I've been using the search function button but have not seen same thing I am experiencing. I recently had a 30k mile service from the dealer and they are amazed on the condition of the car. I bought the car last Nov 2009 with 10k miles.
Any input will be appreciated.
Grab a can of PB Blaster, and a flashlight. Lay down on the drivers floor and look up. Follow the clutch pedal up to where you can see where the clutch linkage connects to it, and give it a spray. Move up a little higher to where the top of the pedal pivots on the bracket assembly, and give it some squirts there on both sides. See if that helps.
bigredsauto
04-23-2008 11:43 AM
