Problem with Autometer Oil Press. Unit
Old Mar 15, 2011 | 12:04 AM
Motor60's Avatar
Default Problem with Autometer Oil Press. Unit
The sending unit for autometer oil pressure wont fit in the hole behind manifold. The male fitting on the sender is too short. I have looked EVERYWHERE for a brass fitting to use as an extension, but no luck. I read I can hook up sender somewhere near oil filter. Can anybody upload a pic to show me where? I saw a hole near the oil filter but its slightly larger than the sending unit threads. Or, I found ****** fittings. One will go into the hole and one will attach to the sending unit. I will attach a 1/8" hose in between the fitting on the block and the sending unit. Will this work? Almost like a mechanical gauge. But then how do i ground the sending unit? Somebody please help!
Old Mar 15, 2011 | 12:05 AM
Motor60's Avatar
The ***** is supposed to say ******. Wonder what happened?
Old Mar 15, 2011 | 12:06 AM
Motor60's Avatar
What the! Ok the **** is supposed to say B A R B E D. OR guess i can say hose fittings.
Old Mar 15, 2011 | 12:20 AM
Go to the hardware store plumbing section and get one of these: http://www.plumbingfittingsdirect.com/galv2.html
and one of these: http://www.plumbingfittingsdirect.com/galv1/80009.html
Then screw your sending unit into the coupler. You can use black pipe if you don't like galvanized. Don't forget the teflon tape too.
Old Mar 15, 2011 | 10:24 AM
Motor60's Avatar
The problem is if the adapter is too high, then the distributor gets in the way. Unless I get an elbow. Does anyone have a picture of the hole near the oil filter?
mike6208
Aug 27, 2011 07:57 PM
Spartan66
Jan 5, 2008 06:26 AM
White Zombie
Feb 23, 2007 07:26 PM
2002CamaroSSM6
LS Series Tech
Jan 13, 2007 11:42 PM
alxinya
Jul 8, 2006 07:55 AM
