Autometer Fuel gauge help
Old Aug 26, 2011 | 07:07 PM
mike6208's Avatar
Default Autometer Fuel gauge help
so i installed my autometer fuel gauge, used the stock wires from the old cluster connector, tan for fuel unit, pink for ignition and black for ground, when i turn the car on, the fuel gauge goes straight to past full, and e when the car is turned off.. i know my car doesnt have a full tank it prob has about half. can anyone help here? does the stock fuel sending unit not work well with autometer?
Old Aug 26, 2011 | 08:53 PM
mike6208's Avatar
did my own troubleshooting and found the prob. cannot find the delete post button. if a mod wants to delete it, go ahead.
Old Aug 26, 2011 | 08:56 PM
Pablo63's Avatar
Banned
From: Raised in Tilton NH now residing in Kings Mountain KY
More often than not the ground is the culprit.
Old Aug 26, 2011 | 08:58 PM
Pablo63's Avatar
Banned
So was it a bad ground?
Old Aug 26, 2011 | 09:11 PM
mike6208's Avatar
actually found out the wires were switched on my stock harness, which also explains why my tach wasnt working when i bought the car. found the right fuel sender wire and it works
Old Aug 27, 2011 | 08:11 AM
camaros4evr's Avatar
GM Torque Strap question: In order to race at an NHRA track, we needed to have some sort of backup torque strap ( to keep the engine from jumpin out of the car if a mount should break). We are running Energy Suspension polyurathane engine mount inserts. Guess that isn't enough, recently aquired a 2nd Gen. chevelle torque strap, which I hear was a quick fix recall deal back in the day. Does anyone have a picture of one of these installed? or anyone old enough to remember these? It has an aircraft wire that goes around the upper control arm and a bracket that goes to the exhaust manifold, with our headers, it doesn't seem to want to line up with anything, Any ideas gang? any help would be appreciated. Thanks Bob
Old Aug 27, 2011 | 04:43 PM
Pablo63's Avatar
Banned
Bob, a little advice. When you have a question you should start your own thread. What you are doing by interrupting this thread is referred to as "high jacking". Your taking attention away from the original subject.
Old Aug 27, 2011 | 07:57 PM
Wow talk about off topic. I would use a chain from the head to the subframe, anyway. Carry on.
1989_RALLYSPORT
Feb 26, 2009 11:00 AM
vzfox
Nov 10, 2007 10:05 PM
BlueKitsune
Oct 5, 2007 07:54 PM
2002CamaroSSM6
LS Series Tech
Jan 13, 2007 11:42 PM
alxinya
Jul 8, 2006 07:55 AM
