speed density to MAF conversion?
Old May 10, 2011 | 07:45 PM
porterjiles's Avatar
Default speed density to MAF conversion?
i have a 93 z28 with a speed density lt1 and a 700r4 trans. i am in need of a new motor and am in the process of looking this week and hope to have it running asap. but my question is what would i need to change over if i were to put a MAF from 94-97 in my car as far as ECU and wire harness ect. this is my first time swaping a motor so there are quite a few things that stump me. what should i be looking for? stick with Speed density or swap to MAF? and what do i need to change if i do?
thanks
Kyle
Old May 11, 2011 | 11:10 AM
You would need a PCM from either a 94 or 95 car, the 96 to 97 are OBDII and use a different front engine cover. You would also need a 94-95 wiring harness, a MAF sensor, all the plumbing for the MAF, and you will still need a MAP sensor. The PCM will have to be reprogrammed to delete the transmission because it is set up with the electronic 4L60e transmission, and will set codes if it does not find one.
Old May 11, 2011 | 03:34 PM
the 93 transmission uses some info from the ecu for shifting and converter lock. 93 is one that locks up in 3rd at higher mph. just so you know the lt1 motor itself is the same from 93 to 97 and can be used in your 93. i have a 96 block heads and intake in mine.
Michael Snyder
82-92 V8 Tech
Mar 17, 2009 10:12 AM
robmnrd
Jan 21, 2008 10:13 AM
CCarRocks
Nov 24, 2007 10:09 PM
wreckgarr50
Jun 21, 2007 07:03 PM
CdnMaverick
Oct 4, 2006 01:15 AM
