Speed Density or MAF
Old Nov 23, 2007 | 09:12 PM
CCarRocks's Avatar
Default Speed Density or MAF
Okay guys I'm thinking of taking the plunge to fuel injected. I haven't read all of the info on chevythunder but will get back to it later tonight.
The one nagging question is which system is more suited for my desires, speed density or mass air flow. I never know when the bug to change something in my engine is going to hit me. So what are the pro's & con's to each system.
Is there an end user programmable control unit out there? Most of the ones I see you have ot buy a chip, so how do you change the map to get the most out of your engine. Certainly things need to be or can betweaked for the most out of your setup....right?
Give all your ideas & input please.
Thanks,
CCar
Old Nov 24, 2007 | 03:00 PM
Default RE: Speed Density or MAF
Are you going to use a factory controller or a racing type after market unit?
Old Nov 24, 2007 | 10:09 PM
CCarRocks's Avatar
Is there an after market unit that can be configured by the end user? I may try to piece together a setup so the ECM is going toneed to be thought out. Basically I want to be able to take it to someone locally who canhook it up to a lap top or their machine& fine tune thesetup once I have it in the car. From all I've read you have to get a chip made.
Thanks,
CCar
porterjiles
May 11, 2011 03:34 PM
Michael Snyder
82-92 V8 Tech
Mar 17, 2009 10:12 AM
robmnrd
Jan 21, 2008 10:13 AM
wreckgarr50
Jun 21, 2007 07:03 PM
CdnMaverick
Oct 4, 2006 01:15 AM
