Spark plug wires
Old Dec 11, 2008 | 11:57 PM
kyleag89's Avatar
Default Spark plug wires
Ok so I have a couple ticks in my engine. One is solved..(new headers loose). The other problem is that my plug wires are arcing to the block. The wires are brand new along with distributer. Do you think I might have broke the wires when I installed them or is there another reason why the wires would be arcing?
Old Dec 12, 2008 | 12:13 AM
JRs72RS's Avatar
February 2009 ROTM
Default RE: Spark plug wires
Are the wires burned from touching the exhaust? If so you need to reroute and replace.
If you cannot see any damage, I would return them and get my money back.
What brand are they? I have used Taylor wires for years and had zero failures.
Old Dec 12, 2008 | 12:17 AM
t9ojetpilot's Avatar
[&:] spark goes wherever is easiest and it really doesnt want to go into a pressurized cylinder. the plug wires could be bad yes even new especially depending on quality. the plug could be bad and have a crack and or carbon track in the insulator or the gap is too large on the electrode. either way you have a bad plug or wire and its gonna need replacing. once a carbon track has been established in a part its junk and can only be replaced kurt
Old Dec 12, 2008 | 12:19 AM
kyleag89's Avatar
They are red accel performance wires. There is like fiberglass cloth around the wires where they go near the headers. So there is nothing else that could cause this to happen? I don't want to replace all the wires and have it be something else.
Old Dec 12, 2008 | 01:13 AM
frostlime69's Avatar
try a set of heatshields for the boots.
Old Dec 12, 2008 | 05:15 PM
kyleag89's Avatar
Thanks guys... I had heatshields for the boots but they weren't completely covering the boots. I still have a faint tick in my engine but if i give it a little gas about maybe 200rpm higher than idle(800rpm) it goes away so I believe that there is nothing wrong with the engine... Maybe just somthing to do with my disconnected and open emissions tubing.
Volcente
Jan 28, 2012 04:13 PM
JaySan
Mar 22, 2008 11:40 PM
3.4CamaroCDOG
Jan 19, 2008 06:39 PM
Saint_Ali
Jun 22, 2006 08:37 PM
