LT1/LT4 Tech 1993-1997
1997 LT1 Camaro Spark Plugs / Spark Plug Wires / Misfire ... PLEASE HELP!!!
Old Jun 15, 2009 | 12:01 AM
QUICKB4C's Avatar
Unhappy 1997 LT1 Camaro Spark Plugs / Spark Plug Wires / Misfire ... PLEASE HELP!!!
Hey everyone. I need some help regarding some questions with my car. The car is a 1997 Camaro Z28 with 70,000 miles. I'm a newbie to this sight but everyone recommended it. The guys in my car club said there are some good folks on here so I'm hoping they're right. I have not had any problems with the car and the car was running great. Now, at 70,000 miles I decided to do a plug change because I'm not sure when the last time was that they were done since I'm not the original owner of the car. I've done all the mods but the plugs looked original OEM. I bought a set of Bosche 2 Platinum plugs and replaced all the plugs. I took it out for a test drive and had a slight stumble loss of power at low RPM from starting rest to about 65 or 70 MPH. After that speed, it seems to "catch" and run and feel like it's running normal without a hitch. MINOR MINOR rough idle as well. Then it eventually threw some codes. I hooked my scanner up to it and scanned the ECS. I got a P0151, a P0300, and a P0305. For those of you experienced in the OBDII you know that's an O2, a random misfire, and a cylinder 5 misfire. I dismissed the O2 and cleared it because i used a lot of PB blaster on the exhaust and it was bank 2 sensor 2 which is post cat so I didn't see it causing much of problem. I came back home and pulled the number 5 plug, inspected it and RE checked all the plug wires as I checked them all when I did the plug change. I then read on several of these forums, where many people advised against using Bosche and the platinum plugs so then I went to the Chevy dealer and bought some direct AC Delco replacement plugs matching part number and everything from what came out of the engine. I put the Delco plugs in and went out for another test drive. It didn't stumble or misfire or lose power AS BAD but it did the exact same thing. I'm not sure what if anything a simple spark plug change could screw up to cause a misfire when everything was fine before. My only idea is that I might have broken a filament inside a wire moving the wires out of the way to pull the plugs out when I did the plug change. The wires LOOK great but as far as their resistance qualities and internal shape I'm not sure. They APPEAR to be the original OEM wires that came on the car new so I'm not sure they have ever been changed out. If not, then they are probably very brittle from the heat and I don't think it would take much movement to mess them up. I have already ordered a new set of AC Delco wires from the dealer and they will be in on Monday so I will put them on then. My questions are as follows: has anyone had similar issues after something as simple as a spark plug change? If you have or even if you haven't, does anyone have any advice about what could have caused it or what i should do? My oil dip stick has broken the little plastic piece up by the handle so I removed it to keep the piece from traveling down into the oil sump. I don't think this could happen but a friend of mine suggested maybe the problem is from doing the test driving without the oil dipstick in place because the system is not sealed anymore. Does anyone else think this is possible? I dismissed it but I guess anything is possible. And the other questions are more or less brand / type / preference questions. Does anyone have any recommendations or preferences about which spark plugs are the best for this year LT1? And does anyone have any recommendations or preferences about which spark plug wires are the best for this year LT1? Also, I heard so many horror stories bout the spark plug changing on an LT1 and I have to say the first time, I did agree it was a doosy, but now I've got it down to where i can change all 8 in 45 minutes. Does anyone have any suggestions or ideas or links to writeups on how to do an LT1 spark plug wire change? Help on this would be greatly appreciated! And lastly and again I'm repeating, does anyone have any idea what causes this or has it happened to you. Lots of LS1 experiences on the net, not a whole lot of LT1 experience. Please write back. :bang:
Old Jun 15, 2009 | 09:44 AM
plug wires are a pita. i waited till i was changing the opti to change my wires. having the water pump out of the way makes it much easier, still a pain. it does sound like a wire may have a hand in ur issue. what kind of opti do u have?
Old Jun 15, 2009 | 11:52 AM
There is a good chance you may have damaged the wire when you put in new plugs. The wires dry out with age and became brittle. The wires are run very close to metal parts and the exhaust manifolds and any slight damage can cause arching to ground, especially when the engine is under load and cylinder pressure makes firing the plugs harder. In my experience, I found out that for a basically stock engine, the best performance is obtained by using OEM plugs. Your engine originally came with AC R45LTST plugs gapped at 0.050". These are single platinum plugs (center electrode only) . As this engine fires plugs in the normal direction at all times, there is no need for double platinum plugs. Also, because platinum is not a very good conductor, more platinum makes it harder to fire the plug.
BM-Z28KING12
Mar 26, 2012 09:21 AM
Volcente
Jan 28, 2012 04:13 PM
sebi1990
Oct 10, 2010 10:24 PM
C4M4R0 FR34K
Oct 9, 2008 02:46 PM
JaySan
Mar 22, 2008 11:40 PM
