Rearend gears
Old Mar 4, 2009 | 07:06 PM
1981TypeLt's Avatar
Default Rearend gears
Hi!
i have a 1981 camaro with the stock 2.73 gears. i have a friend who is getting 3.73 gears in his 2000 ws6. my question is will the 2000 ws6 gears work with my car?
Old Mar 4, 2009 | 07:29 PM
GRIFF's Avatar
No they will not
Old Mar 5, 2009 | 01:19 PM
LT1RUNNER's Avatar
I think he was looking for a little more info Griff. You can do just about any gear ratio you like. Is the car going to be for track, street or a daily driver? You may want to take that into account before making your choice.
Old Mar 5, 2009 | 01:32 PM
1981TypeLt's Avatar
the car is my daily driver but i will be taking it to the track every now and then. what i really needed to know was if his 3.42 gears can replace my 2.73s?
Old Mar 5, 2009 | 02:01 PM
LT1RUNNER's Avatar
Sure they can. You'll have to get a set made for the rear end you currently have. You can look them up on Summit Racing or Jeggs and you know more or less what the price is also. Make sure you have someone with experience do the install as this is not something a novice would want to tackle.
Old Mar 5, 2009 | 04:04 PM
blackz87's Avatar
You have a 2-series carrier (also in most cases a open one) now and you can not use your friends 3:73 3-series gears. You can buy thicker gear set for the 2-series carrier, but the question is it worth it??
Old Mar 5, 2009 | 08:17 PM
GRIFF's Avatar
I might have misunderstood the question... if the question was will a gear set from a 2000 ws6 fit in a 81 camaro rear end then the answer is no because they are two different rear ends the 81 has a corporate 10 bolt with a 8.5" ring gear and I belive the 2000 has a 7.5 or a 7.6 ring gear. The 8.5 is a stronger rearend...
If the question is can I run a 3.73 gear ratio in my 81s 8.5" rear then the answer is yes you just need to get the series 3 posi and the gears to go along with it... for a 8.5 camaro rear end
Old Mar 6, 2009 | 11:25 PM
1981TypeLt's Avatar
Thank you for all your answers!
I guess I can't fit his gears in mines :\
Texas70z28
70-81 Transmission & Differential
Sep 19, 2013 10:52 AM
Redneck97
Dec 14, 2008 01:29 AM
Redneck97
Dec 8, 2008 04:05 PM
dbess23
Dec 6, 2007 01:58 PM
The_Shadow
Oct 21, 2005 06:47 PM
