Upgrading Rearend Gears
Old Nov 30, 2007 | 12:22 PM
dbess23's Avatar
Default Upgrading Rearend Gears
Is it worth installing new rearend gears? Will itreally improve power andacceleration for the money it costs?i was thinking about installing SLP's Ring and Pinion with the 3.73 ratio.
Old Nov 30, 2007 | 03:37 PM
02StanGT's Avatar
Default RE: Upgrading Rearend Gears
Good choice in size. They worth the money.
Old Nov 30, 2007 | 06:12 PM
deltav's Avatar
ORIGINAL: 02StanGT
What he said. And it's fine if you're not gonna add too much horsepower, these rearends aren't that strong.
Old Dec 1, 2007 | 03:25 AM
dbess23's Avatar
thanks guys.
Old Dec 1, 2007 | 11:31 AM
whammer3024's Avatar
ROTM Winner
what i was told when i was doing mine was if you go with a GM gear, they will be quieter than any aftermarket. something to think about but a 3:73 would be good for your car
Old Dec 2, 2007 | 11:23 AM
98ss4REAL's Avatar
i would get a torque converter with the money before gears u will see more out of it then u will the gears...
Old Dec 2, 2007 | 11:47 AM
blackz87's Avatar
You did not state what car, engine, tanny and present rear gear ratio. Anyone asking about gear changes before other mods are reading too many post on that subject. Some of the basic reasons are:
1) parts are expensive along with the install labor.
2) if the correct cut of gears are not selected, noise problems will occur.
3) NOT a DIY type of job for anyone and problem will happen if not done by the book.
4) If you don't have the horses up front a gear change is a waste.
One of the above posts suggested a Torque Converter and I agree. Just so it in a reasonable range (2500 rpm's) for a daily driver.
Old Dec 4, 2007 | 02:28 AM
armynatguard18's Avatar
i'm going to ask something stupid, but something i've been wanting to know for a while now. You don't have a torque converter if you have a manual do you?
Old Dec 4, 2007 | 06:33 AM
blackz87's Avatar
ORIGINAL: armynatguard18
Automatic tanny= Torque converter
Manual tanny= Clucth
Old Dec 4, 2007 | 03:10 PM
dbess23's Avatar
i have a 2002 ss, auto transmission, with the 345 hp package,3:23 rationo modifications done yet. should I do my exhaust system first?
