How do I tell what rearend gears I have?
Old Oct 19, 2005 | 03:25 AM
The_Shadow's Avatar
Default How do I tell what rearend gears I have?
I have a 89 Iroc. I know it's a posi because I've left rubber from both wheels.
What I don't know is what the gear ratio is. How can I tell?
Thanks in Advance.
Old Oct 19, 2005 | 06:27 PM
thirdgencamaro's Avatar
Default RE: How do I tell what rearend gears I have?
run your vins i think or the rear end may have it some were
Old Oct 20, 2005 | 07:22 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
there is an ID code stamped on the rear, but that may not be much help if someone changed the gearing in the original rear.
Old Oct 20, 2005 | 10:38 PM
thats true but souldent the stock be able to be found in the vins
Old Oct 21, 2005 | 12:41 AM
May have to figure it out the hard way. Pull the rear cover from the rear axle. Count the teeth on the ring gear, count the theet on the pinion gear. Divide the number of theet on the ring gear by the number of theet on the pinion gear, the result is the gear ratio.
Ex: 40 theet on ring, 10 theet on pinion. 40 / 10 = 4.00 ( rear end ratio )
Old Oct 21, 2005 | 02:35 AM
The_Shadow's Avatar
Thanks Everyone
Old Oct 21, 2005 | 06:47 PM
nj85z28's Avatar
February 2012 ROTM
May 2012 ROTM
ORIGINAL: thirdgencamaro
dont think so, as far as i know, its only body and engine
Texas70z28
70-81 Transmission & Differential
Sep 19, 2013 10:52 AM
1981TypeLt
Mar 6, 2009 11:25 PM
Redneck97
Dec 14, 2008 01:29 AM
Redneck97
Dec 8, 2008 04:05 PM
dbess23
Dec 6, 2007 01:58 PM
