Rattle under the car
Old Feb 25, 2009 | 09:43 PM
Zmaro's Avatar
I had the same exhaust problem so I got a new cat and that fixed most of the problem. But after a while I noticed it again so I brought it back to the exhaust shop, they put it on the lift with me there and it turned out to be the O2 sensor. The shop told me that this is a common problem on Chevys. I have a 2000 with the 3.8. Mine makes a lot more noise when it's cold, then gets better once the temp raises. Maybe this will help...
Old Feb 25, 2009 | 11:01 PM
Freshcamaro's Avatar
Originally Posted by Freshcamaro
an also my shifter also has alot of movement in it. ill be in 5th gear an the shifter is vibrating alot. i dont know if they have anything todo with each other but im wandering about both of them.
thats what the busings are for. in the shift linkage
Old Feb 25, 2009 | 11:03 PM
ill check her out. ive got a new "high flow" cat for it... or straight pipe but its whatever. i jus aint got it put on yet.
Old Feb 26, 2009 | 10:41 PM
lt4weeda's Avatar
The shifter on your transmission is pinned on to the housing and that housing bolts on to your tranny. I know they can eventually become loose, which can cause them to vibrate more when you put the car under load or give it full throttle at low rpms
Old Feb 28, 2009 | 09:15 AM
what would be the easyest way of going about thighting that.
Old Mar 17, 2009 | 04:55 PM
Firebird Lady's Avatar
Yeah I agree heat shield on the cat. But it could be the cat itself is lose or jiggling about. Did this car rattle when you bought it or after you got it. If it started after you got it then did you hit and decent bumps? You, now that I think of it, could also have broken a clamp and/or losened the mid pipe.
Nebraskaborn
Oct 1, 2012 01:50 PM
Red Bull
Jul 26, 2010 01:05 AM
typeomang
Jun 26, 2010 10:31 AM
JimmyHoffa1997
Jun 23, 2010 05:39 PM
Y2KCamaro
Oct 16, 2008 11:22 PM
