oil filter question
Old Mar 12, 2008 | 10:08 PM
bigjsmashman's Avatar
Default oil filter question
I was just wondering if it would hurt anything to put a larger oil filter on my car.I have an 85 with a 350 in it ,and I noticed that 350s of the same year ,but in a truck had longer oil filters .Same gasket size, threads etc...just bigger .can i use one?
Josh
Old Mar 12, 2008 | 10:14 PM
Default RE: oil filter question
The truck filter will work fine, but you still should change it at every oil change.
Old Mar 13, 2008 | 12:28 AM
SpecterGT260's Avatar
Ninja Administrator
the rubber gasket and thread sizes are all that really matters. the length of the filter is more for fitment, however a bigger filter really wont help you any. If the fitment isnt an issue at all (which some times they can be in goofy spots, not sure about ur motor) then u can use whichever is readily available
Old Mar 13, 2008 | 06:42 AM
blackz87's Avatar
I have used the A/C Delco truck filter for My IROC for 20 yrs now with no problems. The two qt filer is like having a larger oil pan without there problems. I like the idea of the eztra oil capacity and cooling.
Also it the only reason I Go to the Dealer for a oil change isbecause they are only ones with that filter I know will fit.
Old Mar 13, 2008 | 10:33 AM
Cool thanks guys I appreciate it.
OptimusPrimer93
Apr 4, 2013 12:38 AM
Kipp88
Nov 26, 2012 05:49 PM
1997_3.8
Nov 28, 2009 10:25 AM
oliverjohn
May 7, 2009 11:03 AM
Spartan66
Dec 12, 2008 11:55 AM
