no fluid to rear drum brakes
Old Feb 15, 2007 | 12:04 AM
JOHNANDJEN's Avatar
Default no fluid to rear drum brakes
i have a 93 camaro v6 it has no rear brakes
no fluid to them if u try to bleed them
i bleed the abs system but still no rear brakes
any ideals
Old Feb 15, 2007 | 12:26 AM
Default RE: no fluid to rear drum brakes
If the ABS lite is lit, you won't be able to bleed the brakes properly. Also check the proportioning valve.
Old Feb 15, 2007 | 12:42 AM
JOHNANDJEN's Avatar
the abs light is not on
the only light on is the brake light
the rear pads are in good shape
and it does not have trac control
im lost
Old Feb 15, 2007 | 01:14 AM
There is a combination valve on top of the ABS unit that controls the fluid to the rear barakes.
Old Feb 16, 2007 | 03:23 PM
Blade's Avatar
June 2007 ROTM
I can bleed the master cyclinder. The bleeder is on the back on the cyclinder.
Old Mar 6, 2007 | 05:24 AM
JOHNANDJEN's Avatar
how do u bleed a car with abs
i was reading and i guess it is not the same
i bled the rear, then the f,then the abs
thanks for the help guys
Old Mar 6, 2007 | 12:23 PM
You bleed ABS the same as any other brake system, except if there are ABS codes, it won't bleed properly because all the ABS gizmos won't be in the proper position. So, don't bother bleeding if you have ABS codes set.
Old May 8, 2007 | 03:22 AM
libertyforall1776's Avatar
So don't bleed the rear drum brakes if you get the solid ABS Inop light?
Uggh...
ORIGINAL: z28pete
Old May 8, 2007 | 08:30 AM
Blade's Avatar
June 2007 ROTM
check the lines.
camarodude77
Dec 16, 2015 05:52 PM
John 69 Camaro
Dec 9, 2015 11:43 AM
dmoneey05
Jul 14, 2012 05:58 PM
ace5179
Dec 1, 2010 01:36 PM
libertyforall1776
Nov 10, 2007 03:04 PM
