Loud ticking!!!?
Old Jul 3, 2005 | 02:47 PM
IDLE's Avatar
Default Loud ticking!!!?
I just bought a 1996 camero its a 3.4 liter and a automatic transmission. When you start the engine it makes a loud ticking noise so i think im gonna just replace the engine if its a big problem. My question is what do you think is making the tickin and how hard would it be to put a chevy 305 v8 inplace of the 3.4v6. Thanks i really need help.
Old Aug 9, 2005 | 09:43 PM
Default RE: Loud ticking!!!?
If it just ticks for a little while and then quiets down it is probably a bad lifter that bleeds down when the engine is stopped. If you can stand the noise it won't cause any harm. If it ticks continuosly, you should get the lifter fixed before it chews up the cam. If you hear a deep knocking sound from inside the engine, you got big problems.
The car is designed for an LT1 engine and they come in either in 4.3 (260 +- ") or 5.7 (350'). If you want to use a 305 small block. you will wind up with a project not worth the effort. Go for the 350 LT1, it will fit right in and you can pick up the parts needed such as computer from a junked 96.
jml2002
Oct 14, 2012 08:13 PM
Kingscolor
Jan 2, 2012 04:53 PM
jeu510
Dec 31, 2011 10:58 AM
curtis2962
LS Series Tech
Aug 25, 2009 02:49 PM
69camaro1
Oct 11, 2006 11:04 PM
