leaking tranny
Old May 11, 2007 | 02:21 AM
bdam0214's Avatar
Default leaking tranny
I have TH350 tranny that leaks after a drive when car is off. Filler tube is sealed and kickdown cable is connected. Any ideas?. Thanks.
Old May 12, 2007 | 12:47 AM
jdubs1813's Avatar
Default RE: leaking tranny
Where exactly is it leaking from? Have you tried looking underneath to try and pinpoint the spot or is it just to hard to find an exact spot?
Old May 12, 2007 | 10:23 AM
v8chvyguy's Avatar
TH350's like to leak from the selector shaft seal. Sometimes guys will change the seal but not the bushing and it still leaks.
Old May 13, 2007 | 12:19 PM
t9ojetpilot's Avatar
[X(] the pan gasket is often a culprit, the gasket hardens or compresses over time and sometimes just needs to be tightened up or replaced if its time to service it anyway. selector shafts and tail shafts are other common leak areas youll have to wipe it down and watch to determine its exact location kurt
Old Jun 20, 2007 | 02:04 AM
bdam0214's Avatar
I think it is coming from the pan gasket. I tightened the bolts so we will see what happens. Thanks for all the help.
Old Jul 13, 2007 | 03:06 AM
bdam0214's Avatar
Found the leak coming from the filler tube. I tried a few different o rings but its still leaking. Any ideas?
djsquare1
Apr 13, 2015 11:15 AM
bhoeksema
Mar 6, 2010 08:38 PM
mpd228
May 11, 2009 09:52 PM
jakejg
Jul 16, 2008 09:01 PM
Mace587
Sep 18, 2006 12:20 AM
