Ignition Switch Lock Cylinder
Old Jul 19, 2007 | 08:28 PM
jimcamaro's Avatar
Default Ignition Switch Lock Cylinder
I have tried all day long to remove the ignition switch lock cylinder on my 69 camaro. I removed the steering wheel and signal lights. I have a slot on the side of the cylinder but sticking a screwdriver into the slot only removed the bezel nut but not the cylinder itself.
Any suggestions would be appreciated.[/align]
Old Jul 19, 2007 | 09:07 PM
MadMikeZ28's Avatar
Default RE: Ignition Switch Lock Cylinder
I can't recall what the early stuff is like because I done so much later stuff. Is there a screw behind the turn signal switch under the lock cylinder or a hole with a button in it where you need to turn the key and pus on the button while pulling the lock out.
Old Jul 19, 2007 | 09:17 PM
jimcamaro's Avatar
I removed the turn signal arm and did not see any screw behind it.The key has been stuck, but when I removed the bezel nut the key came out. There is no button, but there is a small slot that I have used a screwdriver and a paperclip to see if I could pop it out with no results. Thanks for your help.
Old Jul 19, 2007 | 10:38 PM
MadMikeZ28's Avatar
Ok in that small slot you may need to push on it but the key needs to be turned to release a lock in it.
ShadowCamaro
Mar 30, 2011 03:32 AM
PA68
Oct 30, 2010 11:16 AM
1977Camaro350
Apr 19, 2010 04:55 PM
19Z95
Dec 21, 2009 10:50 PM
Buickwagon
Mar 27, 2007 06:47 PM
