clicking sound...help
Old Oct 10, 2009 | 02:23 PM
mccoyj91's Avatar
Default clicking sound...help
Recently, as I've been driving, I've heard a clicking sound coming from the right side of the rear axle. It seems like every time the axle spins, at a certain point the sound happens, and I have no idea where it is coming from. any ideas?
Old Oct 10, 2009 | 07:34 PM
osduck5's Avatar
Does it have drum brakes or disc on rear? Could be something on the brake loose, parking brake issues, etc. Block the front wheels, jack the rear up and rotate the tires to see if you can pinpoint where the noise is coming from.
Old Oct 12, 2009 | 07:47 AM
bvans's Avatar
just an idea thatd b less expensive to just replace n see if it was the problem -
check the bearing
Old Oct 12, 2009 | 11:49 AM
osduck is on the right track, find the sourse of the noise if posible and it sounds like it could be brakes. could also be driveline. do u have a two piece driveline? could be carrier bearing. also could be something got wrapped up somewhere along the line so check that two.
https://camaroforums.com/forum/lounge-6/blond-drive-shaft-problems-39594/
Old Oct 19, 2009 | 09:39 PM
marvinrbrsn's Avatar
Default hi
Ares Galaxy Turbo Accelerator (AGTA) is a most useful plug-in for
Ares Galaxy file sharing software, built to enhance the latter’s
capabilities and cut the downloading time to the minimum while putting
you in control of your download speed.
Old Oct 23, 2009 | 11:29 AM
gabe74gt's Avatar
first of all, check for any scrap, if stuck to axle, if found none, then may be some part of your car has fallen on axle
Old Oct 24, 2009 | 11:31 AM
mccoyj91's Avatar
Yeah, it just turned out to be a loose lug-nut. I had my oil changed and tires rotated recently, and I guess when they put the wheels back on they didn't tighten them down all the way. needless to say, i'm not going back there again.
Old Oct 27, 2009 | 02:21 AM
lilliansayerseer's Avatar
First you want check for any scrap.
_______________
Lilian
find a job
TheDevilsBreed131
Jul 19, 2014 07:05 PM
NoSoupForYou83
Mar 20, 2013 02:54 PM
sngehl01
Mar 7, 2012 08:35 AM
Cammy 3.8lV6
Nov 12, 2009 11:09 AM
snake10556
Sep 24, 2007 09:09 AM
