Changing from traditional oil to synthetic oil
Old 05-07-2007, 04:27 PM
MadMikeZ28's Avatar
Default RE: Changing from traditional oil to synthetic oil
My 84 had over 100,000 miles on it and my brother took the motor for his S10 blazer swap. Well an A-hole of a co-worker led to the motor needing to be taken apart and my brother was amazed at how clean it was inside. No carbon, no sludge... And this is not to sell seafoam because I never used the stuff.
Old 05-07-2007, 04:33 PM
74454bb's Avatar
May 2007 ROTM
I have heard a lot of good things on here about it , from all kind's , so they all can't be selling it. I would use it on my blazer but it seem every time I do something ti fix it other stuff falls apart, so I'll just run it to the ground.
Old 05-07-2007, 05:55 PM
MadMikeZ28's Avatar
Well the point I was going for is if you take care of your vehicle there is no need for it.
Old 05-07-2007, 06:01 PM
74454bb's Avatar
May 2007 ROTM
I know, It has like 213k on it, at that point I'm almost done takin care of it.........It's kind of like newborn twins at this point, but would like to see what it could do to a dirty motor.
Old 05-13-2007, 12:51 PM
t9ojetpilot's Avatar
[X(] switching to a synthetic is good at any stage of an engine life, while its more expensive it has much better characteristics than petrol based oils. so is it worth it in older motors thats for you to determine(leaks, burns oil, trying to save a dead horse??) its not recommended for engine break in normally because its not abrasive enough to seat the new surfaces, however after break in its use may extend the life of your engine. as for engine or fuel addatives ive never been a fan of most addatives cause for the most part theyre snake oil. there is NOTHING you can do to remove ALL the crap that builds up in an engine except disassemble and clean. ( this is true for every thing automotive there is just no substitute for a proper cleaning or rebuild) i have used very successfully carb and throttle body cleaners, on and in appropriate parts, and for engines a mix of 1/2 ATF 1/2 engine oil to do a light cleaning and unstick some varnished up lifters. the engine must be run until it warms up and then drain the ATF/OIL mix back out(dont forget to change the oil filter). the reason this works for this application is the atf is highly detergent and aids in cleaning.., if you think about it almost all magic in a bottle stuff is an attempted short cut to a proper and more expensive process, do they hurt anything?? probably not , they tend to take 5-10 dollars or more a whack out of the wallet that could be spent on more worthwhile things kurt
Old 05-15-2007, 12:31 PM
ryanh_3's Avatar
here is a good link if you want to know more about it
http://www2.ls1tech.com/forums/showthread.php?t=534376
DashingDaryl
05-21-2012 07:11 PM
REN
05-23-2010 11:16 PM
ztothe28
04-22-2007 07:20 PM
69camarokid
12-05-2006 11:49 PM
Quick Reply: Changing from traditional oil to synthetic oil
