Changing to Synthetic Oil
Old May 23, 2010 | 07:42 PM
REN's Avatar
REN
Default Changing to Synthetic Oil
Read some posts that synthetic oil is recommended. Are there any recommendations on switching over from dino oil? Do you need to clean out the existing oil or can synthetic be mixed with the residual dino oil?
Many Thanks, REN
Old May 23, 2010 | 08:50 PM
libertyforall1776's Avatar
I went full synthetic, and any one is better than regular oil, even Wal-Mart's SuperTech...
Old May 23, 2010 | 09:03 PM
osduck5's Avatar
I just switched 2 vehicles from regualr to full synthetic oil. I was concerned about flushing the system but read several articles on the internet that said there was no need to flush the engine. They referenced several companies that switch from one to the other during different seasons without flushing. So far, no problems. I can't tell much difference with the Suburban but the ole Jeep straight six sure sounds alot quieter than with the reg 10w30 I was running.
Old May 23, 2010 | 09:21 PM
Yes, it's recommended for the LT1 (if that's what you have), and better to use in general. Synthetic is compatible with dino oil, so just treat it like a regular oil & filter change.
Old May 23, 2010 | 09:48 PM
pitbull's Avatar
I can say the same. The synthetic oil is prefferable.
Old May 23, 2010 | 11:16 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
No need to flush, even high end engines dont require flushes. The old stuff will be absorbed by the new stuff and on the next oil change any remnants will go out the drain.
DashingDaryl
May 21, 2012 07:11 PM
jason7504
Oct 26, 2011 10:57 AM
baseballer91
May 4, 2008 05:32 AM
ryanh_3
May 15, 2007 12:31 PM
ztothe28
Apr 22, 2007 07:20 PM
