coolant crossover pipe
Old May 22, 2010 | 09:42 AM
camaro_junky24's Avatar
Default coolant crossover pipe
the coolant crossover pipe on the back of the heads do i need that or can i get rid of it and plug the holes?
Old May 22, 2010 | 10:08 AM
Yes you need the crossover pipe. That's part of the LT1's reverse flow cooling system where the heads get cooled before the block does (opposite of older gen 1 engines like in my 69). That cooling setup keeps head temps down which allows the engine to be able to run the higher compression ratio and timing advance that it has, without detonation.
Old May 22, 2010 | 10:39 AM
crossover pipe is to help bleed the air out. u can do without but its almost impossible to get all the air out without it.
Old May 22, 2010 | 10:56 AM
It's still in the best interest of the engine's cooling design to keep the crossover, GM put it there for a reason. Is it in your way or something, or did it just look at you funny?
Look at this link, and scroll down to the part where it talks about "Steam Vents".
http://www.indipalass.com/ARCHIVE/Te...lingSystem.htm
Old May 23, 2010 | 06:00 PM
thanks guys that helps i have no problem with jujst wondering if i needed it is all
Old May 23, 2010 | 11:46 PM
Why are so many people eager to get rid of parts that the factory put in? Most parts have a very good reason for being there. lol
eric forman
Jun 9, 2014 10:00 PM
Greg08
Oct 4, 2012 09:31 AM
supafly147258
Aug 31, 2011 12:16 AM
AnalyzeFaith
Dec 5, 2010 05:54 PM
camaroEMT
82-92 V8 Tech
Aug 31, 2009 06:59 PM
