Coolant fumes + coolant
Old Oct 3, 2012 | 02:11 PM
Greg08's Avatar
Default Coolant fumes + coolant
While driving for awhile my camaro turns into a locomotive. It has fumes coming out of the coolant overflow tank. Sometimes when i turn it off the coolant comes out of the overflow lol.
I'm wondering what i should do?
I've bled the system, nvr overheats
Old Oct 3, 2012 | 02:25 PM
start with a coolant sytem pressure test. it could be one or more of several things. what motor and year?
Old Oct 3, 2012 | 03:14 PM
Have you swapped out the Thermostate? Are the fans turning one?
I would do a pressure test also.
Old Oct 3, 2012 | 07:59 PM
Greg08's Avatar
im going to swap the rad cap, i believe the spring is weak
Old Oct 3, 2012 | 08:22 PM
wayne242's Avatar
If the spring was weak it would just come out of the rad cap. Don't think its a bad head gasket letting exhaust in the coolant system do yoU?
Old Oct 3, 2012 | 09:10 PM
FYI you can borrow a pressure tester from autozone, it comes with a cap tester adapter. They would probably let you test it in the store.
Old Oct 4, 2012 | 09:31 AM
Greg08's Avatar
Now that, would be poopy. lol
Although if the gasket did go bad, it would be a great excuse to get the heads done and do some power adders, as well as nice new head gasket.
I do not think thats whats happening though..
I think the cap spring is weak and letting the coolant go into the overflow way to much.
I will start with the cap. Easiest thing first. If it doesnt fix my issure i will head to autzone Gorn, and pressure test :]
94ChevyCamaroV6
Jul 18, 2012 11:44 PM
AMP3D
Mar 15, 2012 06:55 AM
Camaro3800V6
Aug 17, 2011 03:47 PM
keaboi
Jul 30, 2011 06:59 PM
AnalyzeFaith
Dec 5, 2010 05:54 PM
