brake job
Old Mar 23, 2007 | 08:54 PM
bluovlh8er's Avatar
Default brake job
i just never done one on a car. i have a 98 camaro v6 and need to do front and rear pads and roters. can some one write up a kind of detailed how too................? i do not want to take it in, and want to learn how to so this stuff.
Old Mar 23, 2007 | 09:27 PM
6v49der's Avatar
Default RE: brake job
are the back breaks discs or drums? disc breaks are easy as hell to change, once you have the wheel off and the car on jack stands, there are two alen bolts on the back of the caliper, ( for the front) make sure you have a stool or hanger nearby to keep the caliper on so that you dont stretch the break lines. once the caliper is off, take off the outside pad, and then using ac clamp, push the piston back in onthe inside pad, (making sure not to squeze any break lines) once that is done put the new pads on, the bigger one goes on the outside. The rotor should slide off fairly easily, simply take it off the hub assembly and replace it with a new one. once that is done, place the caliper over the rotor and gently thread the bolts with your hands, then once they are started use the wrench to tighten it up the rest of the way. the back is virtually the same, with much smaller pads. i just changed all my rotors/pads last week and i cant remember what the difference is but pay close attention when you take the back pads off, they look the same at first glance but there is a specific inside and outside pad. same thing with the rotor just slide it off and replace. not sure how big the bolts are in the back but its not an allen wrench situation like the front. make sure you have a long handled wrench, them bolts can be a real ***** to get off
Old Mar 24, 2007 | 02:24 AM
bluovlh8er's Avatar
sounds easy enough lol thanks man
Old Mar 24, 2007 | 09:49 AM
Blade's Avatar
June 2007 ROTM
What I do if I am only changing the pads is leave the bottom bolt of the calibor in and just remove the top, lean it back pull the pads put new ones on and put the calibor back on the rotors. Saves time in fights it back on completely.
Old Mar 24, 2007 | 04:01 PM
microkid's Avatar
March 2011 ROTM
Technical User
me and my dad successfully redid my brakes (everything BUT the front calipers), and neither of us had done brake jobs before. its realy easy, just follow the instructions in a manual, keep parts in order, and take pictures of stuff you might get confused on while reassembling
Old Mar 24, 2007 | 07:25 PM
bluovlh8er's Avatar
hey thanks for the imput. im prolly going attempt it tommarrow...i know there are some ppl like this is so easy i just never done it.
Old Mar 24, 2007 | 08:05 PM
microkid's Avatar
March 2011 ROTM
Technical User
i would reserve and entire weekend for it, and make sure you have a spare car to drive to the parts store because you never know what might not work. mine took a while because i was given incorrect rear rotors, then my dad broke the parking brake cable, then i had 2 faulty calipers, and took me a few weekends to get it all done.
Smittys_z28
Dec 24, 2014 02:14 PM
Willie Anderson
Dec 22, 2012 10:23 AM
XxCaMeLxxToSiSxX
Dec 8, 2010 11:27 PM
jp 71 camaro
Nov 7, 2010 08:36 PM
tyler2497
Mar 10, 2007 03:35 AM
