Brake help..
Old Dec 20, 2014 | 03:47 PM
Smittys_z28's Avatar
Default Brake help..
I have a quick ? Will some rear disc brake calipers off a 98 z28 fit a 94 z28?
Old Dec 20, 2014 | 09:33 PM
i believe you have to change the axles to do it.
Old Dec 21, 2014 | 06:05 AM
Just to use the brake calipers?
Old Dec 21, 2014 | 08:11 AM
thats what i was seeing on a search, it seems its easier to use c6 brakes. in any case its the fronts that need the upgrade, all the weight is up there so rears don't do much and if you upgrade the rear without doing the front you will have issues with abs.
Old Dec 24, 2014 | 02:14 PM
MKCoconuts's Avatar
You would need to get everything off the rear as far as brakes go. The '98 and up models have the parking brake inside the rotor compared to being part of the caliper assembly as it is in the earlier models.
I don't believe you'd need to change axles, but you would need the backing plate for the parking brake, the parking brake cables, the parking brake shoes and hardware, calipers and rotors.
Willie Anderson
Dec 22, 2012 10:23 AM
XxCaMeLxxToSiSxX
Dec 8, 2010 11:27 PM
jp 71 camaro
Nov 7, 2010 08:36 PM
camaromanz28z06
Jun 4, 2010 07:26 PM
tyler2497
Mar 10, 2007 03:35 AM
