98 starts hard when warm
Old 12-07-2010, 09:35 PM
do you have oil leaking down onto the starter? check and make sure starter bolts are tight and wire connection is clean and tight while your down there.
Old 12-08-2010, 07:58 PM
XxCaMeLxxToSiSxX
Guest
Posts: n/a
sorry, I should be more informative, the car cranks over great just doesn't start right off like normal, takes 10-20 seconds instead of the normal instant startup. Its not all the time only when warm and only occasionly. The starter cranks great.
Old 12-08-2010, 09:28 PM
ok good start would be to check fuel pressure and scann for trouble codes, a failing coil can give weak spark when warmed.
CZimmer
05-15-2012 06:49 AM
je43278
02-11-2010 08:03 PM
Mesosneaky
07-29-2009 04:48 PM
Pdy
10-17-2008 09:17 PM
Quick Reply: 98 starts hard when warm
