fuel gauge and hard starts
Old Oct 2, 2008 | 03:41 AM
Pdy's Avatar
Pdy
Default fuel gauge and hard starts
hi everyone, this is my first post... so i really dont know what to write however i have a having a few small issues with my 95 z28. It has a worked jasper crate engine, and a few other mods so im around 380 hp. my fuel gauge is always inaccurate, when i fill up it only goes to like 7/8 and it will just say what ever it wants to say, i am also having hard starts. my question is will a higher gph pump and a new sending unit fix these proplems, or is there an easier fix?
Old Oct 2, 2008 | 06:54 PM
kyphur's Avatar
Default RE: fuel gauge and hard starts
Hard start could be a timing problem. What are you running your timing at?
Also, is the fuel gauge stock or aftermarket?
Old Oct 3, 2008 | 03:22 PM
Pdy's Avatar
Pdy
idk what my timing is at, my buddy's shop did my motor i can ask him, but the gauge is stock, it also almost didnt start the other day took alot of cranking and eventually it turned over
Old Oct 3, 2008 | 07:59 PM
kyphur's Avatar
When you say hard starts do you think it might be because it's flooded? When it cranks does it blow a lot of dark/blackish smoke that slowly goes away?
Also, your stock fuel gauge might just be going bad. If it was an aftermarket one I could suggest you might've gotten one that reads the wrong ohms rating.
Old Oct 4, 2008 | 07:15 PM
Pdy's Avatar
Pdy
so it would just be the gauge.. not the sending unit?
no theres no smoke but it doesnt turn over, somedays it will be perfectly fine but when it is a little colder outside it seems to have trouble
Old Oct 17, 2008 | 09:17 PM
kyphur's Avatar
Sorry for the long time before the response. Totally missed it. Are you still having problems?
The gauge would be a simple of test with an ampmeter and checking the ohms at a full tank and almost empty. If you're within tolerances for your year model then you know it's the gauge.
Well if it's just doing it when it's cold outside it could be that it's just the fact that it's a carbureted car. Does it have an electric choke? Also, does it have the stock manifolds with a heat riser?
XxCaMeLxxToSiSxX
Dec 8, 2010 09:28 PM
je43278
Feb 11, 2010 08:03 PM
vzfox
Nov 10, 2007 10:05 PM
BlueKitsune
Oct 5, 2007 07:54 PM
