'91 Camaro with a fan problem
Old Apr 25, 2009 | 08:38 AM
riffwraith's Avatar
Default '91 Camaro with a fan problem
Hi - if anyone has any idea, they will be appreciated.
The other day, I am driving to my gf's house. I get off the hwy, and it takes me a few to go down the side streets to get to her house. I see the engine temp is getting way too hot. I made it to her house, but barely - the temp gauge was all the way in the red and the coolant was gurgling slightly. I waited until the car cooled a bit - still too hot to drive, but cooled down enough to start for a few - and started it. The fan is not working. So, I get the owner's manual, see which fuse is for the fan relay, and even tho the fuse looked good, swapped it with another 20 ma fuse. No fan. So here I am thinking the fan relay is bad. I start driving the next morning, the car gets up to about 220, and the fan kicks in. Ok....
The same thing happened last night. I am driving for about an hour, and the temp is fine - fan is running. Then the temp gets too high - no fan. Several hours later, I start the car, let it run for a bit, and the fan kicks in.
Anyone have any ideas here? My mode of thinking originally was that if the relay was bad, it would just not work - but it does - usually. Thoughts?
Thanks in advance.
Itsalifestylee
Dec 13, 2010 08:00 PM
hendogg1114
LS Series Tech
Jul 14, 2009 09:24 PM
akajoe87
Feb 17, 2009 02:35 PM
80s don
Dec 3, 2006 10:31 PM
80s don
Dec 2, 2006 12:44 AM
