74 Camaro - Possible Electrical Problem?
Old May 25, 2009 | 04:51 PM
bvans's Avatar
Default 74 Camaro - Possible Electrical Problem?
Hey guys,
So I have an auto tranny in my camaro LT,
but when i change gears to drive, reverse, etc..
on the dashboard it doesn't show that i'm in a different gear, it indicates Park all the time.
I'm wondering if this is why my reverse lights dont work? I just replaced the bulbs, still not working
Anyone know if this is just a disconnected cable to the dash, or?
And - My MPH when parked shows 5 mph, and while i'm driving, sometimes it doesnt show the right reading (i go 70 it shows 45)
And the other day i was turning into my street slowly, and it showed 40 mph then slowly went down..
Couple problems.. Any ideas?
Old May 28, 2009 | 05:19 AM
THe problems are unrelated. Both the speedo and the shift linkage are mechanical. Is the car a floor shift or colum?
Old May 28, 2009 | 11:42 AM
Look towards the base of the steering column, inside the engine compartment. Sticking out on the engine side of the column, you should see a big tab with a hole. There should be a linkage bar connected to that, which is connected to your shift linkage. If nothing is on that tab, then that's why your indicator isn't moving.
Your reverse lights is an electrical problem. You have either a switch on your console shifter (if you have one), or a switch on the trans, or your switch could be M.I.A. altogether.
Old May 28, 2009 | 06:09 PM
bvans's Avatar
shes a floor shift
camaro 69, ill go take a look for a tab n the linkage bar, thanks for the info
Old May 28, 2009 | 08:19 PM
bvans's Avatar
just took a look and nope, nothings on the tab comin out the steering column
how much $ in parts do you think is going to be necessary?
Old May 28, 2009 | 08:23 PM
Probably going to need to go shopping at ebay or craigslist for used parts.
Or look at classicindustries.com to see if they carry new.
Old May 28, 2009 | 08:29 PM
whitealexander's Avatar
yep i found some good stuffs on ebay recently.. maybe you can find some too..
Old May 28, 2009 | 08:38 PM
bvans's Avatar
aight thanks guys i appreciate the help
i just got headlight bezels for 5$ a few weeks ago on ebay
r_2016
Nov 12, 2012 11:32 AM
greenmachine96
Apr 28, 2011 08:03 PM
cautioncones
Nov 3, 2009 02:12 PM
Shmack2004
Mar 10, 2007 02:38 PM
Number1Dad
Jan 31, 2007 01:26 PM
