electrical problem, need help
Old Mar 9, 2007 | 01:07 PM
Shmack2004's Avatar
Default electrical problem, need help
my parking and tail lights do not work on my 85 iroc, i think they are on the same curcuit because they run off the same fuse. every fuse i put in blows when i turn the lights on so its a pinched wire somewhere. where ar the wires routed? inside, outside?
Old Mar 9, 2007 | 05:35 PM
MadMikeZ28's Avatar
Default RE: electrical problem, need help
You could check your headlight switch. There is a 10 gauge wire on there that gets hot and will melt the plastic connector
And you could pull the bulbs out and if the fuse dont blow put them back in until it blows again to give you an idea of which light is giving the problems. It may also be a bad socket.
Old Mar 9, 2007 | 08:38 PM
Shmack2004's Avatar
its just the running lights (parking and tail) turn signal work fine, headlights work fine, foglights work fine.
what happened was i ran over a bush...so i thought it might be a shoft in the front so i re-wired the whole front parking lights and got no result,
could it really be the switch?
every time i pull the switch to turn them on the fuse blows as soon as i pull it.
are the wires to the tailights outside the car or inside?
Old Mar 10, 2007 | 02:38 PM
Shmack2004's Avatar
i took the switch out and saw what you ment be the connector being melted, before i wire in a new connector is there something i can do to stop it from happening again?
sosexpress
67-69 V8 Tech
Oct 12, 2010 09:41 AM
Bobby95z28
Jul 7, 2010 03:52 PM
chadimus06
Mar 13, 2009 09:19 PM
pistolpete_67
Feb 10, 2007 01:12 PM
92CAMARO
Apr 1, 2006 11:02 PM
