Electrical Problem.
Old Feb 9, 2007 | 10:35 PM
pistolpete_67's Avatar
Default Electrical Problem.
So on my 67 camaro, when it's idiling and I turn the lights on the car almost dies, like it's drawing too much power to keep it running, Also when it's idiling with the lights on, and I turn the blinker or flashers on and everytime the flasher goes onand off the car will bog and almost die everytime. I think it must have something to do with the voltage regulator, so I'm wondering if anyone else has ever had this problem, or knows anything about voltage regulators, is there a way to test them? Thank you....
Old Feb 10, 2007 | 01:12 PM
Default RE: Electrical Problem.
I am assuming you have an alternator. Check & clean all your cable conections, including ground cables, and wiring between alternator & regulator, if you have a stand alone regulator.If you still have problems, get your alternator, regulator, & battery tested. Also, sounds silly, but check your belts and for loose alternator pulley.
sosexpress
67-69 V8 Tech
Oct 12, 2010 09:41 AM
Bobby95z28
Jul 7, 2010 03:52 PM
user 7208220
May 13, 2009 02:47 PM
chadimus06
Mar 13, 2009 09:19 PM
92CAMARO
Apr 1, 2006 11:02 PM
