Located my coolant leak... *Pics up*
Old May 28, 2009 | 05:56 PM
bvans's Avatar
Default Located my coolant leak... *Pics up*
Hey guys so I was just taking a look and located where my leak is at
I'm not familiar with all the names of the engine components so I've posted some pictures, hopefully you could help me out..
Would this just require a gasket replacement?
Engine hasn't been run in 24 hours, but a drop of either water or coolant falls every 10 seconds
In the last picture, you can see the leak dripping onto the bolts below.. No coolant coming out from around the bolts
Old May 28, 2009 | 07:20 PM
that is the water pump. did u try to tighten the bolts a little to see if there tight. it looks like u could just replace the gasket although if your pulling the water pump it may be a good idea to replace the pump also if u can afford it.
Old May 28, 2009 | 07:25 PM
bvans's Avatar
the pump is new from what i know,
alright i'll definitely look into some gaskets and see if the problem is fixed
Old May 28, 2009 | 08:37 PM
whitealexander's Avatar
well you can tighten it up a little bit.. btw what is that green oozing on it?
Old May 28, 2009 | 08:39 PM
bvans's Avatar
coolant leaking
stan1277
Aug 8, 2010 01:39 PM
ayagle
Jul 24, 2010 06:04 AM
mccoyj91
Mar 10, 2010 08:35 PM
GMDCAMARO
Jul 12, 2009 12:29 PM
VTXed
Nov 25, 2006 12:04 AM
