where is the coolant sensor located on a 95 Z28?
Old Aug 5, 2010 | 02:56 PM
stan1277's Avatar
Default where is the coolant sensor located on a 95 Z28?
ok my low coolant light is on most of the time on my dash, i checked the coolant level and its full...so i was wondering where is the location of the sensor so i can change it, and is it hard to change? thanks guys..
Old Aug 5, 2010 | 03:05 PM
Right side of radiator, facing engine. Did you check level by removing radiator cap? Using the dipstick in the overflow container can give erroneous results at times.
Old Aug 5, 2010 | 06:25 PM
heres a picture if you need.
http://shbox.com/1/low_coolant.jpg
Old Aug 6, 2010 | 12:34 AM
stan1277's Avatar
right side meaning driver or passenger side, cant really tell from the pic...and do i have to remove any hoses or anything to get it out? is it hard? thanks
Old Aug 6, 2010 | 01:11 AM
yes passenger side. you can see the radiator cap in the one pic.
Old Aug 6, 2010 | 08:59 PM
stan1277's Avatar
is it hard to get to and replace?
Old Aug 7, 2010 | 07:25 AM
Grandpaswagon's Avatar
Not hard. You can get one at almost any autoparts store. You only need a pair of pliers to remove the retaining spring (don't lose it), and some more coolant to replace what you need to drain out. Good time for a full cooling system flush and service while you are changing the sensor.
Old Aug 8, 2010 | 01:39 PM
stan1277's Avatar
thanks alot, ill do that soon.
Triangle12
Jun 28, 2012 08:34 PM
EagleRex
Jul 20, 2010 03:36 PM
kimbers99camaro
Jun 13, 2010 09:20 PM
kimbers99camaro
Jun 13, 2010 05:29 PM
bvans
May 28, 2009 08:39 PM
