4L60E P1810 TFP valve assembly
Old Jun 19, 2007 | 04:43 PM
MadMikeZ28's Avatar
Default 4L60E P1810 TFP valve assembly
Any one know how to test this valve assembly? Or what I can check for this code? I tested for power to it at the round conector. I have power to all three teminals and to the "E" Terminal.
This code popped up a couple of times. Also the vehicle had stalled but restarted, without having to crank the engine, while coasting in D4 or nuetral. I thought that may have set the code but there is also a rattling noise that may be due to incorrect pressure.
Old Jun 20, 2007 | 10:29 AM
Default RE: 4L60E P1810 TFP valve assembly
Mike,
If you PM me a FAX number, I can send you a copy of the test procedure. Five pages worth.
Old Jun 21, 2007 | 06:04 PM
MadMikeZ28's Avatar
Thank you Pete!
People in this forum can always count on you to help them out.
79camaro505
Feb 22, 2008 08:02 PM
camarorz28
Nov 30, 2006 09:17 PM
sewerrat
Dec 24, 2005 01:01 AM
