PCV valve, valve covers
Old Feb 8, 2008 | 09:53 PM
79camaro505's Avatar
Default PCV valve, valve covers
Hi i searched a lil about this and didnt really find much, but was wondering. Im building a sb 350 and want to know if i should put completely sealed valve covers on or valve covers with just breathers or use the pcv valve covers like original. whats the difference and pro's and con's to these diff. setups. Any help is much appreciated
Old Feb 8, 2008 | 11:50 PM
firebird69racer's Avatar
Default RE: PCV valve, valve covers
Use the PCV valve like org. you need to keep the gasses from building up inside the motor
Old Feb 9, 2008 | 09:29 AM
blackz87's Avatar
I second the use of the PCV.
Old Feb 9, 2008 | 09:49 AM
Use a PCV valve in one cover, and a vented cap in the other, here's why. Obviously the crankcase needs to breath to displace the air as the pistons move up and down. The PCV valve is hooked up to your intake, and the pressureisSUCKED out of the crankcase (which is better on the engine), instead of it having to be BLOWN out of the crankcase. The vented cap on the other valve cover lets the air in (or more out ifneeded).
Old Feb 10, 2008 | 12:01 AM
ORIGINAL: Camaro 69
This is how the Factory does it. It has a hose that goes from the valve cover to the air cleaner base with a filter element in there, so it will suck in filtered air.
Old Feb 10, 2008 | 01:32 PM
ORIGINAL: firebird69racer
ORIGINAL: Camaro 69
YEP! And how many times have you gone to a car show and saw cars with either one or two push in valve cover breathers with no PCV valves cuz PCV valves don't look cool? By the way, I didn't mention it earlier, but PCV valves can also help to prevent oil gasket leaks too!
Old Feb 10, 2008 | 08:59 PM
And they don't cost you any HP losses like people think
Old Feb 10, 2008 | 10:32 PM
ok sweet thnx for the help. one thing though why do scott shafiroff's mtrs and some of these sick drag cars have sealed fabricated valve covers? this is gonna be between a 450 and 500 horse mtr
Old Feb 11, 2008 | 10:14 PM
ORIGINAL: 79camaro505
If you look real close or if you ask them. They are running a vacuum pump of some sort to create a vacuum in the motor. In the older days they would run a hose with a one way valve to the collector on the headers to suck out the fumes in the motor. But now most use a vacuum pump.
For what you are doing the PCV valve would be just fine
Old Feb 22, 2008 | 08:02 PM
camaro_burns_all's Avatar
VIP member
camaro69 also mentioned something very important. You must have the PCV valves because they certainly do help prevent oil leaks
69Muscle
Aug 10, 2010 12:36 PM
rockstarbass1
82-92 V6 Tech
Nov 2, 2009 10:23 PM
blink18236dude
Mar 16, 2007 01:48 PM
microkid
Nov 12, 2006 10:21 PM
nnickty
Aug 22, 2006 02:25 AM
