1997 cooling fan problems
RE: 1997 cooling fan problems
It typically has four terminals, two of which are current feeds from a fused source of 12-volt electricity. At the relay, there is one current feed into an electromagnetic coil, and one feed into a set of contacts for the switch, which is open. The other terminal for that open switch is connected to the electric motor for the fan. The fourth terminal, also for the coil, is wired to the PCM, which may look at various signals to determine whether or not to provide an electrical ground for that coil.
________________________________________
Autopartswarehouse..ROCKS!\m/
