cooling fan problems
Old Oct 17, 2014 | 05:51 PM
reko's Avatar
Default cooling fan problems
I have a 92 rs with a 350 engine. I recently upgraded the cam and added double timing chain. My radiator cooling fan motor keeps going out. The copper wires in the fan motor literally turned black. What is causing this problem????
Old Oct 18, 2014 | 09:40 PM
GaryDoug's Avatar
When electric motor windings turn dark, it s a sign of overload/overheating. The heat is cooking the "varnish" insulation on the wires. Make sure the airflow is from radiator front to back. Reversed wires can reverse the airflow and cause overloading. Also make sure the airway is unobstructed in the front of the radiator and the back of the fan.
Old Oct 19, 2014 | 06:25 PM
birdman11's Avatar
what are you using for a chip?
c00nass
Oct 26, 2013 04:36 AM
SurfMunkey
Aug 23, 2010 01:07 PM
97wytt-top
Mar 26, 2010 02:51 PM
87 Irock
82-92 V8 Tech
Oct 7, 2009 09:28 AM
dmc_12
Jul 8, 2008 05:11 AM
