Is there a right or left side to the cylinder heads
Old Apr 14, 2010 | 11:24 PM
JumboNuttes's Avatar
Default Is there a right or left side to the cylinder heads
its a GM 350 1976. can they be switched? thanks for the help
Old Apr 14, 2010 | 11:46 PM
yes. you can look if u like, should have same bolt holes on each end.
Old Apr 14, 2010 | 11:49 PM
they do have the same bolt holes but does it matter?
Old Apr 15, 2010 | 12:07 AM
Doesn't matter which head goes on which side, unless only one end of the head has accessory holes. Some heads have accessory holes on both ends, some heads only have them on one end.
Old May 13, 2010 | 09:31 AM
Carolinarednek's Avatar
Just check each head and make sure that they are the same. As long as everything is the same, tjey will fit just fine. I have built several 350's over the years, and never had a problem.
Camaro3800V6
Jul 17, 2013 06:33 PM
borjawil
Mar 24, 2012 11:18 AM
xXOfNiRXx
Feb 25, 2012 04:20 PM
powers96ss
Apr 16, 2006 09:04 PM
00camaro
Mar 9, 2006 03:46 AM
