Shifter Question
Old Apr 23, 2007 | 01:33 AM
73 T Top's Avatar
Default Shifter Question
I was pulling the automatic shifter assembly from a 3rd gen camaro (not sure what year). There were two cables, one went to the transmission to shift and the other went up under the dash near the steering column. What is the cable that goes up to the steering column for?
Old Apr 23, 2007 | 09:26 PM
vampyrico's Avatar
Default RE: Shifter Question
someone correct me if im wrong, but that sounds like your speedometer cable.
Old Apr 23, 2007 | 11:35 PM
nzink's Avatar
yep, speedo cable.
Old Apr 23, 2007 | 11:41 PM
74454bb's Avatar
May 2007 ROTM
yep, or the one that lets you know what gear your in in the dash.
Old Apr 23, 2007 | 11:51 PM
nzink's Avatar
did the third gens have those??
Old Apr 24, 2007 | 12:00 AM
74454bb's Avatar
May 2007 ROTM
not sure,but I know the one on mine runs up yhe colum,and the speedo is above that...........If it's the speedo it wil have a screw cap on it.
Old Apr 24, 2007 | 12:05 AM
73 T Top's Avatar
I dont think its the speedometer cable. Its connected to the button on the shifter ****. When you push on the button, the cable gets pulled.
Old Apr 24, 2007 | 01:32 AM
vampyrico's Avatar
so the cable goes from the shift **** to the dash? if you can get behind the dash check to see if it goes through the firewall. if it stays inside the dash or hooks to an instrument, im lost. but if it goes to something on the engine, it may be a cable that aids in safe shifting, to avoid tranny problems or inefficient shifting.
Old Apr 24, 2007 | 02:01 AM
73 T Top's Avatar
yea it runs from the shift **** up to under the dash. i dont know if it goes back out the firewall, i dont think it does. it goes from the shift ****, under the carpet to the bottom of the firewall on the drivers side, up the firewall, then up near the steering column, and heads towars the steering wheel and gauges but i loose it uo there. next time i go to the junkyard i will check (probably the weekend)
phoenix901223
May 30, 2012 10:18 PM
southw2
67-69 V8 Tech
Jun 12, 2011 09:59 AM
97slpss
Apr 19, 2009 05:39 PM
camaroslp
Aug 5, 2008 12:04 AM
73 T Top
Apr 28, 2007 10:35 PM
