Replace heads on 1967 327....
Old Sep 26, 2009 | 06:44 PM
camaropal's Avatar
Default Replace heads on 1967 327....
A few questions....
1) I had the heads reconditioned. Does it make a difference which side I place a head? Is there a Right & Left head? They appear to be identical except for a 20 & 22 stamped on the front near the 1st and 4th spark plug respectfully.
2) What is the torque spec for the heads?
3) What is the order in which you should tighten the head bolts? Is there a diagram?
Thanks in advance
kwoods8851
Apr 23, 2011 08:42 AM
fbodyhemi69
LS Series Tech
Dec 7, 2009 05:16 PM
SixShooterCamaro
Oct 30, 2009 08:58 PM
1983_JAL
Mar 23, 2007 11:57 PM
