Rebuilding a LT1 and i need your help
Old Dec 8, 2006 | 12:00 PM
fatass91's Avatar
Default Rebuilding a LT1 and i need your help
Ok.. i work at a bodyshop.. and really dont know anything too much about engines and stuff. so my boss said he would rebuild my LT1 if i got all the parts... this is where i need you. what will give me the best bang for my buck.. such as cam and etc. I am in the process of buying my first house so money will be kinda tight.. i realize if you want the power you need the money.. so just gve me the best stuff i need to make it a strong motor... i already have headers
Old Dec 8, 2006 | 04:58 PM
Default RE: Rebuilding a LT1 and i need your help
If you are not looking for a road going locomotive, the stock internals should be OK. You could use a LT4 hot cam kit fpr a little more zip. However, the beest results come by using better flowing heads. After you are all done, make sure to get the PCM tuned to take advantage of all your mods.
SHOoffSS
LS Series Tech
Feb 19, 2012 06:43 AM
NJZ28
70-81 V8 Tech
Sep 11, 2010 10:32 PM
94z
May 16, 2008 02:19 AM
robawitt21
Feb 26, 2008 09:26 PM
MrOz87
Jan 1, 2007 03:51 PM
