questions about boring out 305 tpi
Old May 17, 2007 | 01:27 AM
Chooseup's Avatar
Default questions about boring out 305 tpi
I have a 86 305 tpi the #1 cylinder is not firing so I decided to rebuild might as well bore it out with the rebuild went to summit racing for the rebuild kit just wondering whats the best one to go with the option Im looking at now is piton and ring oversize at 0.060in rod bearing and main bearing undersize at 0.010in or 0.25mm is this a good kit to run with or should I select another
Old May 17, 2007 | 10:00 AM
machineman's Avatar
Default RE: questions about boring out 305 tpi
As an engine builder, I would recommend that you take the block to your local (quality - not the cheapest) machine shopand have them bore it to whatever cleans up the bores. Stay as small on the overbore as possible. I do a lot of +.020" jobs as I like to keep the wall thickness there. There is very little HP (or none) to be gained in the difference of a +.020" to a +.060" so I believe it is preferable to keep it light on the overbore.
Once he bores the block, he can let you know what to order. By the way, ask him to give you a price because I surprise a lot of my walk in customers when I tell them I can easily match Summit or sometimes even be less. Ask your shop guy before you place your order.
Old May 17, 2007 | 12:37 PM
Chooseup's Avatar
Thanks for the advice will do just as you say your the second person tha told me the machine shop would match if not beat summits price
Old May 17, 2007 | 01:30 PM
Excellent advice. Too bad a lot of people fail to follow it.
98RCMARO
May 12, 2008 04:50 PM
94CamaroSFI
Oct 11, 2006 07:35 PM
Saint_Ali
Sep 8, 2006 10:37 PM
eddore
Apr 6, 2006 02:02 AM
L0tuS
82-92 V8 Tech
10
Feb 6, 2006 07:22 PM
