the naturl first step...now what?
Old Jul 21, 2007 | 01:04 PM
#12's Avatar
Default the naturl first step...now what?
ok so the natural first step was a CAI, K&N. now what would be my next step to beef up my 4th gen 2000 z28. i did 3 1/4 inch flowmasters. now what?
Old Jul 21, 2007 | 01:18 PM
95slvrZ28's Avatar
Default RE: the naturl first step...now what?
A good set of LT headers and a new Y pipe.
Old Jul 21, 2007 | 01:58 PM
#12's Avatar
LT is that the brand or the type? and what is the Y pipe for. like i said i already did flowmasters is that similar?
Old Jul 21, 2007 | 06:07 PM
1985RS's Avatar
the y-pipe is what joins the outlets on headers or manifolds into one pipe on one side of the car. a bigger diameter y-pipe will aid in exhaust flow and smooth it out, so your not going from say bigger diameter headers to small y-pipe to big pipe to the mufflers.
Old Jul 22, 2007 | 12:54 AM
95slvrZ28's Avatar
LT stands for "Long Tube." If you put on LT headers you have to get a new Y pipe because you can't connect the collector of the header up to the stock Y pipe location. If you get shortie headers they'll bolt directly up to your stock Y pipe, but then they won't get you anything because the stock Y pipe is known for being extremely restricive.
Old Jul 22, 2007 | 06:29 AM
#12's Avatar
thankyou gentlemen ill have it done by the end of this month if i can, perhaps the beginning of next month
LolVtech
Feb 17, 2014 06:08 PM
Stix80
Jul 25, 2010 07:07 PM
khawkins192002
Jan 29, 2010 10:09 PM
IrocZ28Camaro509
Dec 11, 2009 05:16 PM
cbr600rx7
May 16, 2009 07:02 AM
