Head problems
Do you notice any rubbing on the bottoms of the comp rockers or on the pushrod it sounds like something was binding are they aftermarket pushrods? What did dart say about the stud breaking?
No i didnt notice anything rubbing or binding. they are comp magnum pushrods. dart tried to tell me that the springs were too heavy which makes no sense bc they put them in the heads. I just went ahead and ordered a set of arp rollor studs and a new push rod and i guess ill guess put it back together to see if that fixes the problem.
ORIGINAL: Eric89RS
Griff brings up s good point. Especially with roller rockers, if the push rods are not the proper length, the roller tip can travel right off the valve stem and land on the spring retainer causing problems. I don't quite see the lifters pumping at idle speed, that is usually a high RPM problem. However, the springs could be strong enough to cause the lifter to stay collapsed at idle, which then will have the same effect as a push rod that is too short. The people from Dart may have the right idea.
If you turn over the engine by hand you should see rocker arm geometry problems in the state of a collasped lifter, makes sense to me and should be easy to check. Here is something else to check off of the afr web site ROCKER ARMS:
If you are using Comp. Cams 3/8 Pro Magnum rocker arms you will need to use a longer stud (AFR #6409) because of the thicker trunion on this rocker arm.
Let us know what you find out..
Im sorry but the studs are 7/16 sorry for the mistake. i got my new push rod and i got all the new studs in so ill let u know what i found out. i think what happen is that the one stud broke and jambed under the other one and caused it to break the pushrod.
