LT1/LT4 Tech 1993-1997
expected head problems
Old Jan 31, 2007 | 11:47 PM
illumastar's Avatar
Default expected head problems
I was talking to my neighbor and i was telling him that i want to get new heads for my 93 camaro it has 114K on engine and trans and he told me that if i get new head on my engine that i could expect to blow the lower end out within 6 months because of all the pressure that i will be putting on it is this trure? do i need to rebuild my block in order to put new heads on it
Old Feb 1, 2007 | 01:20 AM
95slvrZ28's Avatar
Default RE: expected head problems
I've never heard of that problem...I suppose it's possible, but your car suddenly lighting on fire, exploading into a giant fireball, thus launching it from the street and having it come down on top of an Hummer is also possible, but not likely...Providing you get heads that are for an LT1 you shouldn't have any issues, maybe if you beat the crap out of your car constantly, but that's expected if you drive it hard.
Old Feb 1, 2007 | 04:48 AM
illumastar's Avatar
thanks thats what i thought
Old Feb 1, 2007 | 11:35 AM
Gentleman Jack's Avatar
I wouldn't put new heads on an engine with 114K on it without going through the block first. but that's just me.
Old Feb 1, 2007 | 01:13 PM
I tend to agree, if the heads are shot there is a good possibility that the bottom end is in the same condition.
Old Feb 1, 2007 | 08:24 PM
95slvrZ28's Avatar
If the heads are going out, then you should check, but if you're replacing the heads for performance reasons with stock compression and better flow, I don't think you'd have any problems...someone correct me if I'm wrong, but it doesn't seem too logical...
Old Feb 1, 2007 | 10:46 PM
illumastar's Avatar
That is why i am replaing the heads would be for a performance upgrade. Right now the car is in great running condition
Old Feb 2, 2007 | 12:18 AM
93fbodcamaro's Avatar
your friend is right ya dont put new heads on a old bottom end end it will only lead to straining lower end in turn blowin it unless the old heads r very clean with no oil deposits or **** like that but still risky
Old Mar 16, 2007 | 04:54 AM
INTENSE_Z's Avatar
if your worried about it while your doing the heads just freshen up the motor while your at it and if you get time not a bad idea to do through the trans too if you will be abusing it, like racing
Old Mar 16, 2007 | 07:09 AM
sellc's Avatar
ORIGINAL: illumastar
Gee I thought this thread was going to be about problems with teeth getting in the way.
Anyway an engine that runs good at 114K should have absolutly no problems if the new heads are installed properly and the front timing cover seals done at the same time as well. Most all of the engines I see kick the bucket are pushing over 190K. Thats still another 85,000 miles that lower end owes you.
Sure in a perfict world you would want to do it all at once. But swapping a set of heads is fairly simple and does not REQUIRE the overhaul of the lower end.
I would say Go4it.
speedjunky18
Jun 10, 2010 09:23 PM
95 z28 camaro
Mar 11, 2008 11:44 AM
6v49der
Mar 24, 2007 10:17 PM
Connerveritas
Jan 22, 2007 05:18 PM
Eric89RS
Nov 4, 2006 04:34 PM
