engine swap
Old Dec 3, 2007 | 06:00 PM
2fast4u's Avatar
Default engine swap
hey i was wondering what all is involved in a 350 engine swapp from a 3.4 l how difficult is it to do what all needs to be changed would i need a new trans or justa performance clutch just any imput would be great
95 3.4 firebird 5 speed
Old Dec 5, 2007 | 08:50 PM
bluovlh8er's Avatar
Default RE: engine swap
please use the search function.
Old Dec 8, 2007 | 02:21 PM
buckfever's Avatar
yes if you woulda used the search function you woulda realized that there is no reason for a v8 swap.. just swap in a 3800 and gut the cat and you will be makin 500hp easy..
Old Dec 11, 2007 | 11:02 AM
LT1RUNNER's Avatar
It all depends on what kind of swap? Fuel injected or carb? I think that if you decide to do that then the carb might be the way to go. If you go fuel injected then you'll need wiring harness, computer etc and that could end up costing more than it's worth.
Old Dec 11, 2007 | 09:54 PM
1969 SS's Avatar
search is a good start but it's probably cheaper to just buy a V-8 car that has the other things needed to hold up to v-8 power
Old Dec 18, 2007 | 11:22 PM
jj71787's Avatar
ORIGINAL: buckfever
so what your sayin i can make my 98 camaro v6 just as fast as a ss?
Old Dec 19, 2007 | 03:23 AM
02StanGT's Avatar
I hope that's not a serious question...
To the original poster: http://www.tacreationsusa.com/3_4_3_8_v6_to_lt1.htm
http://www.tacreationsusa.com/3_4_3_8_v6_to_ls1.htm
3800_seriesII
Aug 14, 2012 07:24 AM
jrb78
82-92 V8 Tech
11
Dec 16, 2007 07:05 PM
cachaco736
Dec 11, 2007 11:12 AM
uradumass5695
Oct 21, 2006 08:27 AM
illumastar
Oct 20, 2006 01:42 PM
