95 Firebird knocks/rattles
Old Jan 7, 2011 | 05:50 PM
marlboroa's Avatar
Default 95 Firebird knocks/rattles
My wifes car started to make a knocking/rattling sound. I will not do it untill the car has be running for about 5 minutes and warms up. The car was low on oil when this started. The motor still has all its power and runs fine except for the loud fast knocking sound. what all could this be? I think i should start looking at the pushrods and rockers. Any help is appricated. thanks
Old Jan 7, 2011 | 08:26 PM
valvetrain noise is more of a rattle or tick, most times knocking would be a connecting rod. can you post a recording of it?
Old Jan 8, 2011 | 12:43 AM
How low are we talking about? If the oil level went dangerously low, you could have trashed the rod and/or main bearings. "Rod knock" tends to be more evident once the engine warms up, when bearing tolerances change, and the oil thins out. Bad lifters generally make noise upon start up, which makes me suspect the lower end. What is your oil pressure gauge reading?
Old Jan 8, 2011 | 10:52 AM
marlboroa's Avatar
http://www.youtube.com/watch?v=m0zIjTx4QZ0
heres a video after the car has warmed up for about 5 minutes. oil pressuure is at 80 when its cold and then goes to 40-60 depending on the rpm's. the car has always idled at 1500, thats why its high in the video.
Old Jan 8, 2011 | 01:44 PM
marlboroa's Avatar
ok i went and got a listening stethoscope and to me is sounds like its coming from the front passenger valve cover area. I put the scope on both valve covers and the drivers side just sounds like the lifters and rockers. passenger side sound like lifters and rockers untill you get to the front of the valve cover, then it gets the knocking sound. I also put the scope all over the oil pan and it was just a faint knocking coming from it. I did notice that the oil pan gasket was leaking, guess thats where all the oil went.
Old Jan 8, 2011 | 02:28 PM
That sounds like valvetrain to me, as opposed to a rod knock.
It has more of that hollow "sewing machine" sound.
Old Jan 8, 2011 | 02:33 PM
marlboroa's Avatar
fixing to go get some gaskets and pull the covers off.
skylinrcr01
Aug 21, 2008 10:30 PM
boonders
Apr 18, 2008 03:32 PM
Lacunaa
Jan 7, 2008 03:37 AM
69er
Dec 2, 2006 12:49 PM
concierge11
LS Series Tech
Sep 1, 2005 12:42 PM
