383 stroker.
Old 03-14-2009 | 09:03 AM
chevy21's Avatar
ok so after i get my crank and pistons i take the motor back to the machine shop and just tell them i want the clearance for the rods and crank? sounds easy enough. I actualy thought the pistons would maybe contact the heads id idn't know there wasn't any top end work. thats awesome haha
Old 03-15-2009 | 07:45 AM
359pete's Avatar
why not build a sbc 400 it has the same stroke with larger pistons.
Old 03-15-2009 | 07:55 AM
z28rob18's Avatar
because a 350 would have to be bored to much. the most you can go is .060 over. and thats stretchin it ALOT but your makin the walls real thin. you could go to a 396 with a 3.8xx inch crank bored .030 over but then youll need alot more clearancing.
Old 03-15-2009 | 11:38 AM
robmnrd's Avatar
No, he means to just use a true 400 block, not just the crank from one.
Old 03-15-2009 | 12:23 PM
z28rob18's Avatar
o lol
Old 03-15-2009 | 12:25 PM
robmnrd's Avatar
I don't really see any bonuses to it though. More difficult/expensive to build, and then there's the swap. A 383 makes more sense. haha
Old 03-15-2009 | 01:09 PM
z28rob18's Avatar
also 400s werent the best motor with the heads that hav the steam holes and all. your better off goin 383 or 396
italiafutbol07
01-06-2011 06:31 PM
Sodamhot
10-03-2009 10:05 AM
morphine51
70-81 V8 Tech
02-25-2009 09:26 AM
buckfever
12-15-2007 10:25 PM
travis t
10-29-2007 07:48 AM
Quick Reply: 383 stroker.
