383 stroker.
Old Mar 12, 2009 | 10:11 PM
chevy21's Avatar
Default 383 stroker.
What exactly is done to a 350 to make it the 383.. increasing stroke, what is that. how is it done.
Old Mar 13, 2009 | 01:41 PM
chevy21's Avatar
anyone?
Old Mar 13, 2009 | 02:28 PM
z28rob18's Avatar
a 383 is usually a 350 bored .030 over with a 3.750" stroke crank. the bore and longer stroke gives it the extra cubic inches.
Old Mar 13, 2009 | 02:38 PM
z28rob18's Avatar
o also stroke so you know is the distance the piston travels in the cylinder. (theres a different way to put it) and the way the stroke is increased is with the bigger crank. to pull the rods down farther to increase the distance the rod and piston travel. the overbore has very little change in the cubic inches of the motor. .030 overbore is only 5ci so the rest of the cubes come from the enlarged stroke.
Old Mar 13, 2009 | 02:47 PM
buddy's Avatar
further... When I rebuilt my 350 up to a 383 I had to have the block clearanced to accomodate the longer stroke crankshaft.
I don't know what the actual HP increase was but the you can feel torque in the seat of your pants.
This with high lift rockers and mild comp cam.. well.. it's just a smile maker
Old Mar 13, 2009 | 02:58 PM
z28rob18's Avatar
yea the block needs to be clearance lik said. also stroker motors are more torquey then traditional 350s and all
Old Mar 13, 2009 | 03:27 PM
robmnrd's Avatar
A good saying about strokers is 'Big Block torque with small block size'. It's not 100% true, but relatively speaking a stroker will put down pretty large torque numbers for the size.
Old Mar 13, 2009 | 08:06 PM
chevy21's Avatar
ok what is exactly meant by clearance what will i have to do to get that done or rdy for the longer stroked crank
Old Mar 14, 2009 | 06:56 AM
z28rob18's Avatar
the machine shop will do that. if you look where the crank is with the longer stroke if you dont hav it clearanced the rods will hit the block where the oil pan sit. if you look close in this pick you can see how close the rods come. ill post a better pic later tonight of wat the clearance spots looks lik. and some of the rod bolts are shaved for this
Old Mar 14, 2009 | 07:54 AM
z28rob18's Avatar
ok got the pics if you look at the rod bolt its shaved down in the one pic some are shaved more and some none at all. and if you look at the block you can see little notches in spots.
