1994 z28 high res problem
Old Jan 18, 2010 | 12:22 PM
d-champ's Avatar
Question 1994 z28 high res problem
i bought this 94 z28 with lt1 put a tranny in it and it was driving fine. Then i went to town one day and it died and wouldnt start back up till the next day. i pulged it in and it had a high res code . Now it only tries to fire every once in a while. this is what i have changed starter,coil,icm,fuel filter. i dont know what it is maybe opti spark???? or pcm??? Has anyone had the happen before? i need help plz?? I also checked the harness to so i think its the pcm. And should the high res wire have a signal?? mine doesnt thanks David
Old Jan 18, 2010 | 09:59 PM
High res pulse is generated by the Opti.
wiebes11
May 19, 2013 05:50 PM
SYDEWAYZSS
LS Series Tech
Sep 11, 2011 11:09 PM
CNCman
Aug 26, 2009 11:15 AM
bbarroso
Sep 24, 2007 11:55 AM
1994Z
Feb 12, 2007 02:36 AM
