1994 V6 Fan problem
Old Sep 14, 2007 | 03:26 PM
bbarroso's Avatar
Default 1994 V6 Fan problem
My 1994 cooling fan only works with A/C on. Where do I start looking?
Thanks
Old Sep 14, 2007 | 04:35 PM
Default RE: 1994 V6 Fan problem
Start with the engine coolant temp sensor, not the temp gage sensor.
Old Sep 14, 2007 | 05:04 PM
Iowa87CamaroRS's Avatar
this is not the place to post this problem...please visit the gen of your camaro on our message board and post please
Old Sep 14, 2007 | 09:17 PM
riceeater's Avatar
Yeah, I am gonna play mod like Iowa an say welcome, but please keep questions in either gen specific sections or some place designed for it, this is for welcoming members, thanks
Old Sep 15, 2007 | 02:20 PM
bbarroso's Avatar
Pete,
How do I reprogram the PCM for the 160 thermostat in my 1994 V6 camaro? Thanks
Old Sep 15, 2007 | 03:33 PM
You can try a held held programmer, like Hypertech, or find a shop that has the tuning software. Considering what it costs to get the PCM tuned to properly utilize the 160 t'stat, and the small amount of power gain, if any, it will give, personally I would forget about it, or put in a manual switch for the fan.
Old Sep 24, 2007 | 04:48 AM
Cosentino's Avatar
94's are 4th Gen...
Anyways...check your coolant temp switch and your thermostat. A stuck thermostat won't let the coolant by the coolant temp switch heat up fast enough for the fan to come on.
Old Sep 24, 2007 | 11:55 AM
Your car really does not have a temp switch for the fan, but the PCM uses the signal from the ECT sensor, among other uses,to command the fan ON & OFF.At one timethere was a dedicated thermoswitch for the fan.
wiebes11
May 19, 2013 05:50 PM
Spindy12
Jul 21, 2010 03:40 AM
d-champ
Jan 18, 2010 09:59 PM
CNCman
Aug 26, 2009 11:15 AM
1994Z
Feb 12, 2007 02:36 AM
